Motorola One 5G UW Speaker Replacement
  1. Motorola One 5G UW Speaker Replacement, Backglass Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola One 5G UW Speaker Replacement, Backglass Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, let the battery drain below 25%. Power off your phone before disassembly.
    • Flip the phone on it's screen as it opens from the back.
    • First, insert the Jimmy into the side of the phone (as seen in picture). Create a gap big enough to use a plastic pick to avoid removing part of the color film.
    • The back panel on my phone is transparent, yours should be blue.
  2. Motorola One 5G UW Speaker Replacement, Undo Shield: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola One 5G UW Speaker Replacement, Undo Shield: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now we need to disconnect the battery. There are 10 screws in the way, so let's remove them. These screws are the same size, so no need to organize them. Lift up the shield using the notch next to the top left camera.
  3. Motorola One 5G UW Speaker Replacement, Disconnect Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use plastic pick when disconnecting the battery.
  4. Motorola One 5G UW Speaker Replacement, Removing Second Shield and Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola One 5G UW Speaker Replacement, Removing Second Shield and Speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now we go to the bottom of the phone, where we find 6 more pesky screws that we need to remove.
    • Next, pop off the cover, which is also the speaker assembly. You will need to be careful around the antennae wires, if you do pop one off, just reconnect them.
To reassemble your device, follow these instructions in reverse order. When plugging the battery back in, you will need to use your hand as the plastic pick will not be able to line up the connectors properly.
Cell Phone Helper
crwdns2935283:011/03/24crwdne2935283:0
460 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 103
