Motorola Moto Z Play Battery Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Motorola Moto Z Play Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the six 3.2 mm screws securing the lower cover.
  2. Motorola Moto Z Play Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up and remove the lower cover.
    • If you use a tool, don't pry against the battery or motherboard.
  3. Motorola Moto Z Play Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery by prying its connector straight up from the motherboard.
  4. Motorola Moto Z Play Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is strongly glued into place.
    • Peel up the black pull tab at the top edge of the battery, and slowly pull it away from the battery at about a 45-degree angle to release the command strips (a.k.a. stretch-release adhesive) underneath.
    • If the command strips break or the black pull tab is missing, you can still remove the battery using heat and/or isopropyl alcohol to weaken the adhesive.
    • Apply some high concentration (>90%) isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    • Alternatively, apply a freshly heated iOpener to the back of the phone directly behind the battery for two minutes to help soften the adhesive. Re-heat and reapply the iOpener as necessary.
  5. Motorola Moto Z Play Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • When using tools to pry up the battery, be careful not to damage the two orange flex cables hidden underneath the battery's top edge.
    • Insert several opening picks or a plastic card along the outer edge of the battery.
    • Apply steady, even pressure to slowly lever the battery up and out of the phone.
    • If necessary, use several rounds of heating and pressure to slowly weaken the adhesive, and the battery will begin to separate.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  6. Motorola Moto Z Play Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue pulling up the battery until all the adhesive releases from the rear case.
  7. Motorola Moto Z Play Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Do not reuse the battery after it has been removed. The stress of removal can cause hidden damage to the battery cell, creating a potential safety hazard. Replace it with a new battery.
  8. Motorola Moto Z Play Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before installing your new battery, peel up all the old adhesive and remove it from the phone.
    • For best results, clean the area underneath the battery with isopropyl alcohol and a lint-free cloth or coffee filter. This helps prep the surface so the new battery will adhere more strongly.
  9. Motorola Moto Z Play Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
  10. Motorola Moto Z Play Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto Z Play Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the remaining film liners to expose the adhesive before pressing your new battery into place.
    • Carefully position the battery and press it firmly and evenly into the phone.
    • Connect the battery to the motherboard, and install the lower cover, including its six T3 Torx screws.
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
443,296 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,990crwdne2935297:0
Hola, necesito saber como cambiar el pin de carga, el usb-c hace falso contacto y me gustaría saber como reemplazarlo
Juan Calandria - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 115
