Motorola Moto G9 Plus/Power Disassembly
  1. Motorola Moto G9 Plus/Power Disassembly, Remove sim card and memory holder: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G9 Plus/Power Disassembly, Remove sim card and memory holder: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place phone on a suitable surface. You'll be working on the back, so protect the screen (unless you're replacing it).
    • Start by removing the sim card and memory chip holder.
  2. Motorola Moto G9 Plus/Power Disassembly, Remove back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G9 Plus/Power Disassembly, Remove back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now you want to remove the back cover. You can do this by sliding a thin plastic pry round the edges between the cover and the screen. The cover will click off as you work your way round it.
    • Don't pull the cover once it's coming free. The "M" symbol (fingerprint scanner) is glued to the cover so if you yank it, it'll snap and you'll break it.
    • Once the cover is free, gently heat round the "M" sensor and it will loosen the glue. Lightly press on the M and it will pop off. Once that's happened, you can remove the back cover.
  3. Motorola Moto G9 Plus/Power Disassembly, Remove PCB covers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G9 Plus/Power Disassembly, Remove PCB covers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G9 Plus/Power Disassembly, Remove PCB covers: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two PCB covers, one at the bottom and one at the top.
    • These are held in place with Torx screws and are ridiculously fiddly. Remove all the screws (note that there is a screw below the finger print sensor)
    • Once the screws are removed, you should be able to pry the covers off the two PCBs.
  4. Motorola Moto G9 Plus/Power Disassembly, Remove the finger print sensor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the fingerprint sensor connector from where it mates to the main board.
    • Put the sensor to one side
  5. Motorola Moto G9 Plus/Power Disassembly, Remove other connectors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 3 connectors on the main board. Remove all these
    • Battery connector
    • Screen connector
    • Interboard connector
    • Removing the battery is tough. It's glued into the casing and you'll have to lever it out.
    • Use something that is reasonably broad to start levering the battery out. It'll probably bend as you do this (it can be flattened again after removal).
    • Continue to lever it out. Eventually you'll get through all the glue and the battery will pop out.
  6. Motorola Moto G9 Plus/Power Disassembly, Lever out the screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lever out the screen. It wont be that securely put together.
Andrew McLennan
crwdns2935283:009/17/21crwdne2935283:0
214 crwdns2915208:0crwdne2915208:0
Hola . Gracias . Soy nuevo en esto .y mí primer arreglo . Se agradece ..fue muy util
Abrazos desde la argentina .
Slds
Maxicontrol Fumigaciones - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 2,207
