The speaker in the Motorola Moto G7 is a basic bottom-ported speaker made by Dolby Audio. The speaker is used to transmit noise out of the phone without any external headphones or Bluetooth speaker used. A broken speaker may consist of poor audio quality or no audio at all with the volume turned on.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning, make sure the device is unplugged from any chargers or headphones. Before starting, grab suggested tools and a new speaker.
Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
Excessive glass and adhesive around the edges should be removed with the spudger.
Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
Use a spudger to gently take off the metal piece that was held down by the screws.
A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
This would also be a good place to disconnect the battery connector, which is right under the display connector.
At this point, one could remove the battery. I don't see why the remaining steps are necessary.
there is one more piece to remove here. 3 black screws (T3 but longer) and the part visible above the battery on the last image above. Empty space on the top of the image in step 5.
Remove three 3.7mm T3 Torx screws from the bottom of the phone.
Use the spudger to gently lift the speaker out of the phone.
Super, und womit klebe ich das jetzt wieder zusammen??
Could you perhaps offer any advice on how to source one of these bottom-ported speakers?
I just destroyed my screen by dividing it in two parts. You have to be extra careful to dig deep enough in the first step, so you lift the entire screen unit!
Michael - crwdns2934203:0crwdne2934203:0
Thanks... I almost did just that!
Carlisle “Mike” Wick - crwdns2934203:0crwdne2934203:0
I didn't have a problem seperating the screen on my moto G7 or moto Gplay (2021) because the battery "expanded" after 2 years and caused a partial clean separation of the screen and main unit.
The expansion is due to excessive charging mot claims on their support website.
jeff lee - crwdns2934203:0crwdne2934203:0
