Motorola Moto G7 Screen Replacement
  1. Motorola Moto G7 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
    I just destroyed my screen by dividing it in two parts. You have to be extra careful to dig deep enough in the first step, so you lift the entire screen unit!
    Michael - crwdns2934203:0crwdne2934203:0
    I didn't have a problem seperating the screen on my moto G7 or moto Gplay (2021) because the battery "expanded" after 2 years and caused a partial clean separation of the screen and main unit.
    The expansion is due to excessive charging mot claims on their support website.
    jeff lee - crwdns2934203:0crwdne2934203:0
  2. Motorola Moto G7 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
    This would also be a good place to disconnect the battery connector, which is right under the display connector.
    Daniel Kim - crwdns2934203:0crwdne2934203:0
    At this point, one could remove the battery. I don't see why the remaining steps are necessary.
    Kimball - crwdns2934203:0crwdne2934203:0
    there is one more piece to remove here. 3 black screws (T3 but longer) and the part visible above the battery on the last image above. Empty space on the top of the image in step 5.
    Tadeusz Liszka - crwdns2934203:0crwdne2934203:0
crwdns2935229:016crwdne2935229:0
Peter Nelson
crwdns2935283:001/23/20crwdne2935283:0
783 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G6, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G6, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G6
crwdns2935297:020crwdne2935297:0
The replacement part listed here on iFixit indicates installation adhesive is not included. Can you reuse the adhesive on the old part? If not, what adhesive is recommended for this type of repair?
Gabe LaBounty - crwdns2934203:0crwdne2934203:0
You can’t. I used the 1 mil tape and it worked.
Javier Vilalta - crwdns2934203:0crwdne2934203:0
How much would it cost to send this in for someone else to put in a new screen?
Nathaniel Mcvay - crwdns2934203:0crwdne2934203:0
Muito bom,mas tem que botar um tradutor , porque estar tudo em inglês.
Rodrigo Rodrigues Santos - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 12,885
