Motorola Moto G7 Plus Screen Replacement
  1. Motorola Moto G7 Plus Screen Replacement, Remove the Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Plus Screen Replacement, Remove the Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
    Dont pry deeper than 3 mm. If you are deeper and just under the glass you will damage the display. The sceen are two layers. Obe witk the veru thin glass and one with a metal frame with display. Yoy want to get under both layers to lift the screen.
    Magnus Tuvendal - crwdns2934203:0crwdne2934203:0
    Correcting autocorrect… Dont pry deeper than 3 mm. If you are deeper and just under the glass you will damage the display. The screen is two layers. One with the very thin glass and one with a metal frame with the lcd-display. Yoy want to get under both layers to lift the screen.
    I don’t have a thermal gun. Here’s what I did. I wrapped my phone in a baggie and an added an oven thermometer into a heating pad and monitored the heat that way. I left it for awhile (to allow all heat to dissipate) and the heat was 189-degrees Fahrenheit. One hour, toasty warm. So I worked with that.
    Harry A - crwdns2934203:0crwdne2934203:0
    So after one hour at 180 degrees Fahrenheit the base already started buckling and removed itself from the screen. So it was easy to remove the base from the screen. There was some rubber thread that I had to remove. Because of that, I understand that now my phone is not water-tight and I need to treat it as such. But the battery replacement went fine and everything is working great after it was all placed back together. I hope to get a few more years out of my G7 plus!
    Magnus Tuvendal's tip was very helpful: between screen and body frame there are actually two gaps visible. The upper one between the glass plate and its frame is actually easier to get into. But it's the wrong one. The lower one towards the body is the one to go for.
    Peter Klausner - crwdns2934203:0crwdne2934203:0
  2. Motorola Moto G7 Plus Screen Replacement, Remove the Display Cable Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Plus Screen Replacement, Remove the Display Cable Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
    The plate in mine had a small strip of adhesive, so I had to gently heat the plate+strip after removal to separate them.
    Joe Hopfield - crwdns2934203:0crwdne2934203:0
  3. Motorola Moto G7 Plus Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Plus Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of the spudger to lift the metal casing where circled.
    In my case, the display connector was glued to the metal and came off with. Putting back the metal lid did not position it correctly. I had to pry it from the metal and plug it in directly.
  4. Motorola Moto G7 Plus Screen Replacement, Separate the Display From the Phone: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Plus Screen Replacement, Separate the Display From the Phone: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
crwdns2935229:09crwdne2935229:0
Xander Wallace
crwdns2935283:002/10/20crwdne2935283:0
245 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G5, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S22-G5, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S22G5
crwdns2935297:019crwdne2935297:0
crwdns2947412:013crwdne2947412:0
Althrough a simple fix, one should be weary if the glass is shattered. I just did this, and there were a few spliters left on the adhesive, and of course sticking to it. So if you want to replace your screen due to broken glass, make sure to wear protection and remove the splinters carefully, otherwise you may be tempted to press on the new display to strongly, because you want to stick it to the whole brim.
isoein typ - crwdns2934203:0crwdne2934203:0
I completed this fix, and it wasn’t too bad. Just watch out when gluing back the screen not to put glue over the microphone hole at the bottom. This would be the phone microphone mouthpiece, you can see a small notch on the bottom of the screen, beside the “motorola” “m” on the front . I put glue there without knowning and the microphone is now very muted.
Richard Gauvreau - crwdns2934203:0crwdne2934203:0
Thank you for the heads up about the. microphone hole…
Great article! Keep it up, this really helps out us broke fellows.
DIY OR DIE!!!
Michael V -
What can I do if I broke the cable connected to the back
Gary Dixon - crwdns2934203:0crwdne2934203:0
i recently brought a mot g 7 screen replacement and followed the steps and the screen still doesn’t turn on
Javier Ortega - crwdns2934203:0crwdne2934203:0
I am in the same boat. Not sure what else to try here if the replacement screen does not turn on. Try another screen or look at something else. Phone turns on but no screen activity at all
N Wortham -
Short and simple guide for an easy screen replacement - thanks again IFIXIT!
Quick note, Motorola currently (2021) sells a Moto G7 Plus that is actually a rebranded 6.24 inch screen REVVLRY+, model XT1965-T — easily identified by its oval rear camera. It’s always best to check the device model number in the phone’s Settings, if this is possible. This guide works for this phone as well.
With such similarities between the original Moto G7 Plus having a screen size of 6.2 inches, and the the rebranded G7 Plus/REVVLRY+ model’s 6.24 inch scree — both versions using the same display connector — make sure you’ve purchased the correct screen for your model prior to final installation!
Christopher Ingram - crwdns2934203:0crwdne2934203:0
I have a moto g7. Today it overheated in the car, refused to cool. The screen went black and now it boots but the screen doesnt turn on. BUT the touch feature works on the screen. Can receive calls and everything. Just no display. No amount of hard reset works, and getting into recovery is a pain because there’s no telling when to release the power button.
Cole Will - crwdns2934203:0crwdne2934203:0
In my case, all 3 Moto G7 plus phones have the screen assembly separating from the main body - everything else is fine. What glue or tape do I buy to reattach the screen assembly?
Andy Goerdel - crwdns2934203:0crwdne2934203:0
Like Andy has asked, how do you reseal the screen? What type of glue or adhesive should be used?
Simon Gao - crwdns2934203:0crwdne2934203:0
como consigo ver tutorial em video explicando
Thiago De Oliveira - crwdns2934203:0crwdne2934203:0
So, I did as suggested in the turorial and managed to remove the screen, sadly now my battery is fried and the device seems broken. If I want to charge or boot, I only get a blinking LED. I didn't do anything else than the steps described above, yet somehow things got &&^&@@ up. I would strongly suggest to anyone else trying this to remove the battery before unplugging the screen, it feels like that is the only possible source of malfunction. Good luck!
Kev - crwdns2934203:0crwdne2934203:0
Tried replacing a cracked screen today. Sadly, when turning on it didn't show the startup screen. After a while I did get the login screen, but the display was upside-down, while touch screen was right-side-up. After unlocking (some mental gymnastics were required) the colors were very strange. I run LineageOS. Seems I bought a faulty replacement screen.
RHarkes - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 11,409
