The Motorola Moto G7 Plus (model XT1965) features a 3000 mAh Li-Ion battery. If a user has had the phone for a long time, the phone will lose its charge at a much faster rate than when it was new and the battery may need to be replaced. If troubleshooting doesn’t work, use this guide to remove the battery from the Motorola Moto G7 Plus. This guide shows you how to remove the battery with a prerequisite for taking out the screen. Before beginning the repair, make sure the device is turned off, disconnected from any external power sources and discharged to 25% of the device’s battery life for safety. Gather the suggested tools listed below and a new Motorola Moto G7 Plus battery. Heating is optional, but makes adhesive removal easier.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Insert an opening tool pick under the screen, starting at the top of the phone.
Slide the pick around the entire perimeter of the display to break the adhesive.
Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
Gently remove the metal piece that covers the base of the display cable.
The plate in mine had a small strip of adhesive, so I had to gently heat the plate+strip after removal to separate them.
Use the pointed end of the spudger to lift the metal casing where circled.
In my case, the display connector was glued to the metal and came off with. Putting back the metal lid did not position it correctly. I had to pry it from the metal and plug it in directly.
Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
crwdns2935267:0crwdne2935267:0Halberd Spudger$2.99
Use the blade end of a Halberd Spudger to cut through the two strips of black tape attached to the battery.
Use the flat end of a spudger to disconnect the battery from the phone.
Take the battery out with the flat end of the spudger.
Ich habe es gerade gemacht. Jetzt geht mein Handy nicht mehr an :(
Ich weiß nicht ob es nur das Display ist, oder das gesamte Display…
Die Batterie war bei mir stark verklebt. Beim herauslösen ist sie "gebrochen" / "geknickt". Habe durchaus Kraft aufwenden müssen, da der Kleber unterhalb sehr zäh war. Wer dieses Problem auch hat, es hilft, mit einem Föhn das Gerät von unten zu erwärmen....
1. Der Ausbau des Akkus wird wesentlich erleichtert, wenn man das Handy auf ein Gel-Pad legt, das zuvor auf 60 - 70 Grad C erwärmt wurde. Noch einfacher ist es das Handy auf die Druckplatte eines 3D Druckers zu legen und hier die Temperatur entsprechend einzustellen. Ein Gel-Pad zwischen Druckplatte und Handy sorgt für einen besseren Wärmeübergang.
2. Leider fehlt für den Zusammenbau ein Hinweis, wie das Display wieder mit dem Gehäuse am besten verklebt werden soll. 1mm oder 2mm doppelseitiges Klebeband oder Flüssigkleber?
crwdns2935229:015crwdne2935229:0
crwdns2947412:05crwdne2947412:0
bricked, the display is not recognized anymore after re-attaching
as an additional information: my phone is bricked, because i severed a connection of the display, which is located at the bottom of the phone - you should only enter the pick up to a depth of ~ 2-3mm at the bottom!
Went as smoothly as possible, thanks very much. Only the glue under the battery was a serious pain in the butt.
Followed the steps, and now my phone is working again. Thanks for the guide.
bricked too; I somehow got INSIDE the screen. The opening tool pick is shown too far in and I can no longer see my screen when turning on in recovery mode. It should've said to insert only an inch and then just scratch around the screen. At no point should I have inserted the pick.
Dont pry deeper than 3 mm. If you are deeper and just under the glass you will damage the display. The sceen are two layers. Obe witk the veru thin glass and one with a metal frame with display. Yoy want to get under both layers to lift the screen.
Magnus Tuvendal - crwdns2934203:0crwdne2934203:0
Correcting autocorrect… Dont pry deeper than 3 mm. If you are deeper and just under the glass you will damage the display. The screen is two layers. One with the very thin glass and one with a metal frame with the lcd-display. Yoy want to get under both layers to lift the screen.
I don’t have a thermal gun. Here’s what I did. I wrapped my phone in a baggie and an added an oven thermometer into a heating pad and monitored the heat that way. I left it for awhile (to allow all heat to dissipate) and the heat was 189-degrees Fahrenheit. One hour, toasty warm. So I worked with that.
Harry A - crwdns2934203:0crwdne2934203:0
So after one hour at 180 degrees Fahrenheit the base already started buckling and removed itself from the screen. So it was easy to remove the base from the screen. There was some rubber thread that I had to remove. Because of that, I understand that now my phone is not water-tight and I need to treat it as such. But the battery replacement went fine and everything is working great after it was all placed back together. I hope to get a few more years out of my G7 plus!
Magnus Tuvendal's tip was very helpful: between screen and body frame there are actually two gaps visible. The upper one between the glass plate and its frame is actually easier to get into. But it's the wrong one. The lower one towards the body is the one to go for.
Peter Klausner - crwdns2934203:0crwdne2934203:0
