Motorola Moto G7 Play Speaker Replacement
  1. Motorola Moto G7 Play Speaker Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Speaker Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
    How long do you have to use the heat gun before the glue loosens?
    Pamela DeMars - crwdns2934203:0crwdne2934203:0
    It's worked for me with about maybe 15-20 seconds of heating per side.
    Matthieu Bister - crwdns2934203:0crwdne2934203:0
    I could not get the pick started under the cover. Ruined several tips. I started with a hair dryer and switched to a heat gun. Be careful with a heat gun! 😬
    K Goatee - crwdns2934203:0crwdne2934203:0
  2. Motorola Moto G7 Play Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
    My g7 power had a removable connector at the phone side
  4. Motorola Moto G7 Play Speaker Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
    Please add more photos or explain more thoroughly how exactly to remove the motherboard at this stage. (e.g. from top or bottom or left/right, using a flat screwdriver,etc).
    Amy - crwdns2934203:0crwdne2934203:0
    I struggled at this step too. The Battery Replacement guide starts with a crucial step that's missing in this current guide: removing the SIM card.
    Motorola Moto G7 Play Battery Replacement - iFixit Repair Guide
  8. Motorola Moto G7 Play Speaker Replacement, Speaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Speaker Replacement, Speaker: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove the speaker from the top of the phone.
curt caudle
crwdns2935283:002/15/21crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G1, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G1, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S1G1
crwdns2942667:0crwdne2942667:0 1,435
