Motorola Moto G7 Play Charging Port Replacement
  1. Motorola Moto G7 Play Charging Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Charging Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, carefully pry up the charging port assembly cover.
  6. Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an iFixit opening tool, detach the cables from the charging port assembly.
  7. Motorola Moto G7 Play Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, carefully pry up the charging port assembly.
crwdns2935229:010crwdne2935229:0
Monserath Casillas
crwdns2935283:002/10/20crwdne2935283:0
1,203 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G4, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S7-G4, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S7G4
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
Travis Brubaker - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 9,131
