Motorola Moto G7 Play Battery Replacement
  1. Motorola Moto G7 Play Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off device before you begin.
    • Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
    • Press the tool into the hole to eject the tray.
    • Remove SIM Card Tray.
  2. Motorola Moto G7 Play Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case.
  3. Motorola Moto G7 Play Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  4. Motorola Moto G7 Play Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
    You can save a step here by keeping the fingerprint scanner attached as long as the back plate is supported by a minor angle. You’ll detach the other side at the system board in step 7, at which point you can put the whole piece to the side.
    drpotter - crwdns2934203:0crwdne2934203:0
  5. Motorola Moto G7 Play Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, remove the nine 3.2mm Phillips #00 screws from the motherboard cover with a 00 Phillips bit.
  6. Motorola Moto G7 Play Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed.
  7. Motorola Moto G7 Play Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an iFixit opener tool, detach the fingerprint sensor and the other 5 cables from the motherboard.
    You’ll also want to detach both two antennas here and note the specific wire and its position on your system’s board. The antennas on mine are closer together, making it easy to re-connect them to the wrong terminal.
  8. Motorola Moto G7 Play Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 0.4mm Phillips #00 screw from the motherboard with a 00 Phillips bit.
  9. Motorola Moto G7 Play Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry up the motherboard from the bottom with an iFixit opener tool.
  10. Motorola Moto G7 Play Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
    • Remove the cover.
    Hello, I’m a new member to IFIXIT and so far your instructions have been crystal clear and easy to follow :) I was wondering if you could inform me on ways I could remove one of the six 3.2 mm screws from the charging port if the screw was stripped? I’m unable to proceed further with your instructions while one of the 3.2 mm screws is stripped.
    Theodore Allah - crwdns2934203:0crwdne2934203:0
  11. Motorola Moto G7 Play Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, carefully pry up the charging port assembly cover.
  12. Motorola Moto G7 Play Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an iFixit opening tool, detach the cables from the charging port assembly.
  13. Motorola Moto G7 Play Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, carefully pry up the charging port assembly.
  14. Motorola Moto G7 Play Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Play Battery Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, break both adhesive strips on the back side of the battery.
    • Using a metal spudger may puncture or damage other components in your device.
    This task needed a fair amount of heat, using both a heated pad (ifixit iOpener) and a hot air gun. Insulated gloves makes this step effortless. Heat both ends just near the adhesive until you think it’ s too hot to touch w/o your gloves, then gently pry the battery out using a long plastic spudger. I started on the right side, broke it free, then worked my way left. A hand held hot air gun here is perfect for this because the adhesive, at a good temperature, cleanly peels away from the battery and stays on the phone surface, making it perfect to reuse.
  15. Motorola Moto G7 Play Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the battery up now that the adhesive has been separated from the battery.
    When beginning re assembly and reusing the backplate seal, a fair amount a heat with a hot hair gun helps to evenly reseal it.
crwdns2935229:015crwdne2935229:0
Monserath Casillas
crwdns2935283:002/10/20crwdne2935283:0
1,188 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G4, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S7-G4, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S7G4
I found this useful although I was dismantling a G7 Power. The screws are in different places but most parts and the the battery are the same or similar. Fortunately, though I discovered that steps 8, 9 and 13 were unnecessary. The motherboard and charging boards could be left in place (only the plastic covers had to come off) while the battery was removed.
keithmoseley - crwdns2934203:0crwdne2934203:0
I successfully changed a battery on a G7 Play. I skipped steps 4, 7, 8, 10, 11, 12, 13, 14, and 15. The instructions for removing the battery are risky. I pried the battery up a little and put constant pressure on it until it came loose which took about 60 seconds. The battery comes with a tiny connector at the end of a ribbon cable. This is plugged into a board, and then the motherboard holds it in place. In general, the phone is not designed for the battery to be replaced which surprised me.
Joe Doll - crwdns2934203:0crwdne2934203:0
Thank you! I successfully disassembled my G7 Play after an unfortunate dive in a lake to let it completely dry. It's now working as new!
Matthieu Bister - crwdns2934203:0crwdne2934203:0
I followed all the steps and my phone will do nothing. Like it has no power any
Any suggestions?
hodgine - crwdns2934203:0crwdne2934203:0
I wouldn't recommend doing this. I somehow managed to disable the touchscreen attempting it myself and basically bricked my phone.
Shawn - crwdns2934203:0crwdne2934203:0
Weird instruction containing a lot of totally superflous steps:
Why removing the fingerprint sensor from backplate?
Why removing the motherboard and charging board?!
Just open the phone, remove the nine screws of the mainboard cover disconnect the battery plug, remove the battery with an old credit card e.g. and some heat from a hair-dryer, replace the battery and than everything vice versa. Done!
BTW: It is totally devious and malicious to let users write their comment just to tell them than afterwards that they have to create an account here before thay can post someting!!
I really did not want or need another accout! What is it good for? Absolutely nothing: Just another source of annoying spam and another stupid password to forget! I do not want to get 'updated' about my posts.
Gerry Kessler - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 27,131
