Motorola Moto G5s Plus Display Replacement
  1. Motorola Moto G5s Plus Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G5s Plus Display Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G5s Plus Display Replacement, Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Motorola Moto G5s Plus Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Motorola Moto G5s Plus Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. Motorola Moto G5s Plus Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. Motorola Moto G5s Plus Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Motorola Moto G5s Plus Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Motorola Moto G5s Plus Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Motorola Moto G5s Plus Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G5s Plus Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
crwdns2935229:08crwdne2935229:0
Kevin George
crwdns2935283:010/08/18crwdne2935283:0
1 099 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G5
crwdns2942667:0crwdne2942667:0 4,857
