This guide will walk you through the process of replacing the motherboard in a Motorola Moto G4 Plus phone.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Continue to gently lift the back cover until all plastic clips have been released.
Remove the back cover.
Remove the nineteen 3.1 mm T3 screws securing the midframe.
Use the point of a spudger to pry up the rubber cover over the camera flash connector.
Remove the rubber cover.
Use the point of a spudger to pry up and disconnect the camera flash connector.
Loosen the midframe along the edges and lift it away from the body.
Remove the midframe.
Peel up and remove the tape securing the battery wires.
Peel up and remove the black tape that bridges the battery and the phone.
Slip the point of a spudger underneath the red and black battery wires and gently pry straight up.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers or your fingers to de-route the battery wires from the plastic brackets.
Peel the black pull tab from battery and pull slowly but firmly to separate the battery from the frame.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Remove the battery.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using a spudger, remove the two metal pieces connecting the motherboard to the front casing.
Using tweezers, remove the yellow film connecting the rear camera to the motherboard.
Remove two 4.0 mm T3 Torx screws connecting the motherboard to the front casing.
Using a spudger, lift up and remove the motherboard.
crwdns2935229:033crwdne2935229:0
crwdns2947412:014crwdne2947412:0
sir, my motorola g4-plus suddenly it off . i am not analyzed that problem, please help me
Hi,
My Moto G4 Plus has suddenly Dead. neither it is getting charged nor showing any response.
Please Help me. Its just 13 Months have been passed buying me this.
Sir i have a moto g4 plus handset sir when i press power button the device gets locked and when i press power button to open the phone the phone does not open and i have to restart the phone to unlock it and when i unlock it the phones works properly what could be the problem help me
please help me with the motherboard i wana buy motherboard for moto g4plus . phn got dead no power nothing is cuming even not service centre is ready to repair
i have moto e4 plus handset handset was locked and technician says that mother board proble wthat is the price of mother board
