Motorola Moto G32 Charge Port Replacement
  1. Motorola Moto G32 Charge Port Replacement, Rear panel removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G32 Charge Port Replacement, Rear panel removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by heating the device for about 5-10 minutes at approximately 50-70 degrees celsius
    • Use a suction cup on the rear panel of the device to create an initial gap to slide a guitar pick in and separate the rear panel from the device
    • Remove the sim tray from the device
  2. Motorola Moto G32 Charge Port Replacement, Remove midframe screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all visable screws on the mid frame of the device and store safely using a PH000 screwdriver
  3. Motorola Moto G32 Charge Port Replacement, Removing midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G32 Charge Port Replacement, Removing midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a pick between the coloured frame and the black plastic screen edge and slide it down each edge of the device to unclip the midframe
    • Once the entire midframe has been removed open to the left side carefully as there is a cable plugged into the main board that is short and easy to damage.
  4. Motorola Moto G32 Charge Port Replacement, Disconnecting necessary components: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G32 Charge Port Replacement, Disconnecting necessary components: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G32 Charge Port Replacement, Disconnecting necessary components: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery connector to isolate power to the device to prevent damage during repair
    • Disconnect the ribbon cable for the fingerprint scanner from the motherboard, at this point you can place the midframe aside.
    • Disconnect the antenna connection and the charge port connection
  5. Motorola Moto G32 Charge Port Replacement, Charge port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the loudspeaker and then chargeport board and swap with the new component. Ensuring the water and dust resistant gaskets over the aux port and Type C port are transferred to the new port
  6. Motorola Moto G32 Charge Port Replacement, Finishing up: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat all previous steps in reverse ensuring the battery is plugged in last to prevent damage
    • Re seal the back panel onto the device with a new adhesive gasket, In my case i have cut TESA as close to the original template as possible which for this device will be more than sufficient
Hopefully by this point you should have a working device.
crwdns2935229:05crwdne2935229:0
Ryannm
crwdns2935283:012/15/23crwdne2935283:0
326 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 129
crwdns2942667:0crwdne2942667:0 1,590
