Motorola Moto G100 Screen Replacement
  1. Motorola Moto G100 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screen is broken. Buy replacement screen with prying tools and suction cup.
  2. Motorola Moto G100 Screen Replacement, Loosen screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G100 Screen Replacement, Loosen screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Since the screen is broken, the suction cup won't create a good vacuum. First heat up the screen (carefully) with a hair dryer
    • Then apply ducttape so the suction cup can create a vacuum
    • Pull the screen and put a pick in the gap.
  3. Motorola Moto G100 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G100 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put a second pick in, slide it around and remove the screen
    • Open the screen, mind the flex cable
  4. Motorola Moto G100 Screen Replacement, Remove back panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G100 Screen Replacement, Remove back panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G100 Screen Replacement, Remove back panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Same procedure as the front. If necessary, use the hairdryer to loosen the glue. Damaging the finish seems inevitable, but you'll cover the back with a case anyways.
  5. Motorola Moto G100 Screen Replacement, Remove electronics covers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G100 Screen Replacement, Remove electronics covers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all the screws. Triple check if you've had them all, some were covered by residual foil from the back panel. They all seem to be the same length, so don't bother sorting them. Keep them in a cup so you don't lose them
    • Do the same for the bottom cover.
  6. Motorola Moto G100 Screen Replacement, Removing the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G100 Screen Replacement, Removing the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be extremely careful here!!! The battery is fragile and can catch fire if punctured or damaged. It is glued down extremely well. Heat it up from the screen side with the hairblower so we prevent heating the battery too much.
    • Try to get a credit card underneath to cut through the glue. Prevent the battery from bending.
  7. Motorola Moto G100 Screen Replacement, Remove the screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the flex cable connector of the screen off. Pull the flex cable loose and replace the screen
    • Reverse all steps to reassemble.
Erik Ottema
crwdns2935283:012/21/24crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 193
