Motorola Moto G Stylus 4G (2023) Charging Port Replacement
  1. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick along the edges to separate the camera lens glass from the board. If you begin to pry where the picture indicates, you will only get the top plastic and it will peal away from the paint. Instead begin at the gap in the lower left hand corner where there is a space between the actual frame that contains the lenses and the phone.
  4. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Ringer Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove seven 4 mm screws with the T5 Torx screwdriver.
  10. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker using an ESD-safe spudger.
  11. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Charging Port: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the two antenna heads and main ribbon connector cable from the charging port board.
  12. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the faulty charging port from the device body.
Camille Holley
crwdns2935283:002/14/24crwdne2935283:0
609 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-2, Sneed Spring 2024 crwdns2935289:0University of Memphis, Team 3-2, Sneed Spring 2024crwdne2935289:0
UM-SNEED-S24S3G2
crwdns2942667:0crwdne2942667:0 592
