If your Moto G Power 5G (2023) is no longer taking clear photos—or not taking photos at all—it could be due to a cracked or malfunctioning rear camera which is integrated into the motherboard. This issue may result from physical damage, internal hardware failure, or long-term wear. Before replacing the camera, make sure you’ve ruled out simpler causes like app glitches, low storage, or a dirty lens. This repair involves opening the device, so be prepared with the right tools and a clean workspace.
Hold the power button, tap “Power off,” and wait for the screen to go black.
Slide an iFixit opening pick along the edge seam of the phone to loosen the adhesive. Work slowly around the phone until the back cover begins to lift.
Use a Torx T5 screwdriver to remove fourteen 2.2 mm screws securing the internal cover edges.
Use the iFixit opening pick to gently pry off the back camera casing.
Remove the three 2.2 mm screws that were underneath the back camera casing using a Torx T5 screwdriver.
Remove the SD card by ejecting the SIM/SD tray from the side of the phone.
Remove the side casing from the phone by gently prying along the edges. Start from underneath the section of where the SD card was removed.
Unfold the six small tabs carefully to access the internal components beneath.
Use an iFixit opening tool to pry the motherboard out of the device.
