Motorola Moto G 1st Generation Headphone Jack Replacement
  1. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Motorola Moto G 1st Generation Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
    • In some version of this phone, a microSD memory card can be installed. If so, you must also remove these cards.
    • Be careful as to not damage the microSD memory card. Unlike the SIM card, pushing this in may not spring release, as there may not be an eject mechanism.
    • If there is no spring release eject mechanism, hopefully your microSD card has a ridge/raised edge that you can push on with your fingernail or plastic/rubber tool to push the card out. This may be difficult - be patient and do not use excessive force/sharp tools that could cause permanent damage and permanent loss of data.
  3. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Back Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Back Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Back Plate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
  4. Motorola Moto G 1st Generation Headphone Jack Replacement, The Inside of your Phone: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, The Inside of your Phone: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, The Inside of your Phone: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
  5. Motorola Moto G 1st Generation Headphone Jack Replacement, Locating the headphone jack: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The headphone jack is located on the inside of the inner back case. It is directly in the middle and has approximately 5 gold strips that stick out. Located in green highlighted circle.
    • Be careful not to touch the gold strips. They are delicate and easily broken and ruined.
  6. Motorola Moto G 1st Generation Headphone Jack Replacement, Taking the Headphone Jack Out: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, Taking the Headphone Jack Out: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, Taking the Headphone Jack Out: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can use a plastic opening tool, spudger, or your fingers to remove the headphone jack. A plastic opening tool is shown in the picture so that you are able to see the process.
    • On the top of the headphone jack (where the plastic opening tool is) there is a hole. This is where you will put your tool for taking the piece out.
    • Gently pry the jack loose. It should pop out with little to no trouble.
  7. Motorola Moto G 1st Generation Headphone Jack Replacement, End Result: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Headphone Jack Replacement, End Result: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This will be your end result.
    • To replace, take the new headphone jack and line it up with hole. Gently press until it is all the way in and does not wiggle when jostled.
crwdns2935229:013crwdne2935229:0
Rebecca Montgomery
crwdns2935283:009/25/14crwdne2935283:0
3.982 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 1-6, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S1G6
crwdns2935297:017crwdne2935297:0
crwdns2947412:05crwdne2947412:0
I just loved this idea, quite helpful!!
Andy T - crwdns2934203:0crwdne2934203:0
Thank you so much! Clear and simple.
Lorenzo Chiccoli - crwdns2934203:0crwdne2934203:0
My phone kept thinking that it had a hands-free plugged in, so would intermittently mute the microphone and earpiece. Once I had taken it apart, I found some tiny metal shards under the headphone jack connections. I have no idea where they had come from, but removing them fixed the problem.
andyfras126 - crwdns2934203:0crwdne2934203:0
I did not know that changing the audio jack is possible. I thought it is attached to the back cover! Thank you so much!
Conrad Heimbold - crwdns2934203:0crwdne2934203:0
Good clear instructions, but I would add that it is necessary to remove the SIM before removing the inner cover.
Colin Appleyard - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 11,524
