Motorola Moto G 1st Generation Front Camera Replacement
  1. Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Battery Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Front Camera Replacement, Removing the Battery Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Front Camera Replacement, Disconnecting the Front Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Front Camera Replacement, Disconnecting the Front Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard.
    • You want to pry up the black tab that locks it in place. It may be under a protective sticker.
    • Though the battery is removed in our second photo, it is not required for removing the front camera.
  5. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Front Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Front Camera Replacement, Removing the Front Camera: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the camera from the phone by using the tweezers.
    • To reassemble, follow the steps in reverse.
Radostin Lobodov
crwdns2935283:010/16/14crwdne2935283:0
2,925 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G7
crwdns2942667:0crwdne2942667:0 1,386
