Motorola Moto E6 Screen Assembly Replacement
  1. Motorola Moto E6 Screen Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E6 Screen Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Screen Assembly Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Screen Assembly Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Screen Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
    Hi is there a gps chip that can be removed from the motherboard inside of these phones
    burn1987reagan - crwdns2934203:0crwdne2934203:0
  7. Motorola Moto E6 Screen Assembly Replacement, Charging Dock: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  8. Motorola Moto E6 Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  9. Motorola Moto E6 Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
  10. Motorola Moto E6 Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
    The white round sticker, below the top left screw on Step 6, is pink now. Do I need a new charging dock? The sticker on the battery is still white, but I plug in the charger and only a little blue light flashes on the outside top. It doesn’t hold a charge and the screen doesn’t come on anymore. It did until the phone finally died. Im just trying to find the precise problem. And thanks so much! The information and steps were very helpfully accurate.
    Megan Skates - crwdns2934203:0crwdne2934203:0
    Love my moto e6 phone as changing the battery is so simple. When it was clear that the charging port was causing the problem, I wasn't sure where to begin. I didn't want to buy a new phone or have someone else fix it. Was glad to find these instructions on how to change the charging port. Was a bit apprehensive as I didn't want to mess anything up. I ordered the part, but didn't realize I didn't have the correct screwdriver. Was glad to have the specific kind I needed in the instructions. Once I had the right tool following the pictures and instructions made it very easy. A couple of really close up zoomed in pictures would have been even more helpful. This included all the steps needed to replace the charging port. My new port works just fine now. Thank you!!!
    elasue - crwdns2934203:0crwdne2934203:0
    Thank you!! I got the part on Ebay. Had the tool that came with a replacement battery I bought a few years back for another phone and it was the right one for this. Looks like my phone is fixed. Much appreciated!
    hjwellers - crwdns2934203:0crwdne2934203:0
  11. Motorola Moto E6 Screen Assembly Replacement, Screen Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E6 Screen Assembly Replacement, Screen Assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the motherboard and the charging dock, the screen assembly can be replaced.
    How do I replace my cracked screen & where do I get a new screen at…..
    Derrick Jones - crwdns2934203:0crwdne2934203:0
    The above instructions are not complete. Missing removal and installation of speaker, volume keypad, little white rubber dodad at top of phone, and haptic device next to charging dock. I had to use my heat gun to remove above parts. Keypad was difficult to remove and place on new assembly, but I managed. Screen assembly did not include second ribbon cable. Not sure how much easier the ifixit assembly is vs just replacing screen. Also, I had to use heat to remove black sticker covering ribbon cables. If ifixit continues to sell assemblies like this, I suggest having the keypad installed on it and maybe the black sticker with second ribbon cable. The rest of the parts transfer is doable.
    Jon - crwdns2934203:0crwdne2934203:0
Ty Duben
crwdns2935283:009/16/20crwdne2935283:0
139 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G16, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G16, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S2G16
Pro Tip.
The OEM parts for this do not include the flex that connects the Sub to main PBA, nor the earspeaker, nor the buttons or Vibration motor, so all of those will need to be moved over if you are utilizing OEM original components.
Aksel Barnes - crwdns2934203:0crwdne2934203:0
you get me right to the point where i can get to the screen. now, how i do iget it off? put the new one on???
Bobby Browning - crwdns2934203:0crwdne2934203:0
Use heat on the display to loosen the adhesive. Then you can separate the display and put in the new one.
Thaddeus Ervin -
Sorry, these instructions are far from complete.
crwdns2942667:0crwdne2942667:0 3,391
