Motorola Moto E4 Plus Daughterboard Replacement
  1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the antenna cable from its daughterboard socket.
  8. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket.
    • Pry up and disconnect the fingerprint sensor cable next to it from the daughterboard.
  9. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.2 mm long T3 screws securing the daughterboard.
  10. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger under the bottom right corner of the daughterboard and pry up to loosen the daughterboard.
  11. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger underneath the vibration motor and pry upwards to loosen it.
  12. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the daughterboard by the edges and lift it out of its recess.
    • Remove the daughterboard. The vibration motor will be attached to it.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
306,928 crwdns2915208:0crwdne2915208:0
crwdns2935297:0691crwdne2935297:0
Staff
crwdns2935297:023,264crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,697
