Motorola Moto E Display Assembly Replacement
    1. Motorola Moto E Display Assembly Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off the device before beginning.
      • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
      • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
      • You should hear a snapping sound at each corner.
    2. Motorola Moto E Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 14 4mm screws using a T4 Torx screwdriver.
    3. Motorola Moto E Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a plastic opening tool, pry up on the edges of the plastic back cover.
      • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
    4. Motorola Moto E Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
      • Do not touch the connections to the battery in the red square on the picture.
    5. Motorola Moto E Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
      • Move the battery and cover away from the motherboard.
    6. Motorola Moto E Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 1 mm screws using a T4 Torx screwdriver.
    7. Motorola Moto E Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up on the white plastic mount.
      • Pull the orange ribbon cable out gently.
    8. Motorola Moto E Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull the black ribbon cable out.
    9. Motorola Moto E Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the metal spudger, pry the motherboard away from the screen assembly.
    1. Motorola Moto E Display Assembly Replacement, Display Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
      • The phone will be extremely hot. Avoid direct contact with metal pieces.
    2. Motorola Moto E Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently slide the metal spudger underneath the screen and pry it away from the backing.
      • Move the metal spudger under the digitizer and along the entire length of the phone to separate the screen from the adhesive.
      • If the screen was broken, glass shards may come off of the screen and puncture skin.
    3. Motorola Moto E Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue to heat and separate until the screen comes completely apart from the rest of the phone.
    4. Motorola Moto E Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To put the new screen on, press the new screen and digitizer into place, and then reapply heat to adhere the new screen.
crwdns2935229:024crwdne2935229:0
Alex Craig
crwdns2935283:003/11/15crwdne2935283:0
2,611 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 5-7, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 5-7, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S5G7
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 32,171
