Use this guide to replace the motherboard on your Motorola Moto E 2nd Generation.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
            Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
            Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
            Using the same small plastic tool, carefully remove the yellow tape off the connector.
            Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
            Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
            Now that the display is out, remove the aluminum shield off the motherboard.
            Unscrew the single 4mm screw located on the top using a T4 Torx bit.
            After screw is out, gently remove the aluminum shield off the motherboard.
            Using the metal spudger tool, very carefully remove the speaker by first gently prying up on the right side and then the bottom.
            Unscrew the remaining 16- 4mm screws using a T4 Torx bit.
            Next remove the plastic C-shaped black plastic frame.
            Using the metal spudger tool, gently pull up the right corner as indicated and work your way around until it's off the motherboard.
            Gently lift up the battery cable connector, it should come out very easy.
            After the battery cable is disconnected from the motherboard, use the metal spudger tool and carefully insert it in the small opening by the speaker and pry the motherboard up enough to fit your finger in between the motherboard and the phone frame.
            Now just pull the motherboard starting from the top to bottom off the phone case.
crwdns2935229:019crwdne2935229:0
crwdns2947412:05crwdne2947412:0
La verdad la dificultad no es difícil debería ser dificultad media fue muy fácil quitar la pantalla con las herramientas adecuadas sin necesidad de la pistola de calor, gracias por sus guías siempre son muy buenas.
Hello,
Do you have any links to buy a motherboard or other stuff for this phone ? Like sim card reader or antenna ?
Thank you !
probably mentioning something about the ribbon cable being tight in step 2 of the guide. I was careful in removing the screen but not careful enough :-(
this motherboard cost ????????????????????????
Display light problem help
