crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
Using the same small plastic tool, carefully remove the yellow tape off the connector.
Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
Now that the display is out, remove the aluminum shield off the motherboard.
Unscrew the single 4mm screw located on the top using a T4 Torx bit.
After screw is out, gently remove the aluminum shield off the motherboard.
Using the metal spudger tool, very carefully remove the speaker by first gently prying up on the right side and then the bottom.
crwdns2935229:010crwdne2935229:0
Olá André. Gostaria de saber se aquela peça a direita do earpiece speaker é outro falante.
Questiono pq o meu Moto E2 apresenta um som meio chiado nas ligações, porém no viva voz ou reproduzindo mídia o som é limpo, normal.
Obrigado.
I almost bought another phone but I read it was common for these phones to have ear piece issues like mine does.
Thank You so much for the information it was perfect, I just ordered the ear piece.
Ciao Andre e grazie davvero!
