Use this guide to replace the lower case on your Motorola Moto 360 3rd Gen smartwatch.
crwdns2935267:0crwdne2935267:0Halberd Spudger$2.99
Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
Raise the cover without straining the connected ribbon cable.
Disconnect the ribbon cable from the motherboard with a halberd spudger.
