Take care when handling the Moto 360 because it is very fragile. Also, take extreme caution when using tools. Use this guide to replace the vibration motor in your device.
Use your finger or the tip of a spudger to compress the pin securing the watch band.
With the pin compressed, remove the watch band.
Insert an opening tool to into the small notch next to the microphone hole.
Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
Remove the trim ring.
Use an opening tool to slowly pry the button trim ring straight up.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a small pin spanner to unscrew the button.
Remove the button.
While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
Use a spudger to lift the locking flap on the display ZIF connector.
Lift the display cable straight out of its connector on the motherboard.
Use the flat end of a spudger to gently pry the battery out of the case.
Use tweezers to lift out the grey plastic cover over the battery connector.
Use the point of a spudger to pry up the battery connector and disconnect the battery.
After removing the battery the vibration motor will be visible.
Using a soldering iron, carefully remove the vibration motor by applying the tool under the vibration motor.
