Motorola MC5590 Charging Port Replacement
  1. Motorola MC5590 Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push in the battery release button.
  2. Motorola MC5590 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out battery.
  3. Motorola MC5590 Charging Port Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard cover.
  8. Motorola MC5590 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Charging Port Replacement, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement, Speaker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Charging Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Charging Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 Charging Port Replacement, LCD Screen: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MC5590 Charging Port Replacement, LCD Screen: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MC5590 Charging Port Replacement, LCD Screen: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 Charging Port Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 Charging Port Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 Charging Port Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
  18. Motorola MC5590 Charging Port Replacement, Internal Antenna: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MC5590 Charging Port Replacement, Internal Antenna: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
  19. Motorola MC5590 Charging Port Replacement, Charging Port: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws (3 mm long) at the bottom of the motherboard using a PH00-bit screwdriver.
    • Disconnect the charging port from the rest of the device.
Tyler Jean
crwdns2935283:002/22/18crwdne2935283:0
555 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Cagle Spring 2018 crwdns2935289:0USF Tampa, Team S1-G6, Cagle Spring 2018crwdne2935289:0
USFT-CAGLE-S18S1G6
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 380
