Motorola MBP667CONNECT Speaker Replacement
  1. Motorola MBP667CONNECT Speaker Replacement, Camera Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement, Camera Stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger to remove the casing.
  3. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black circular plastic part.
  5. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white plastic wire housing beneath the black plastic.
  6. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now, remove the bottom of the stand by pulling it from the camera.
  7. Motorola MBP667CONNECT Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Phillips #1 screws on the back of the device.
    • Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
  8. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing.
    • Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
  9. Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MBP667CONNECT Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the soldering iron, desolder the speaker wires that are attached to the circuit board.
    • Use caution while handling the soldering iron. This tool gets very hot!
    • After desoldering the speaker wires, remove the wires from the circuit board.
    • Thread the wires from the new speaker wires through the holes in the circuit board. Using the soldering iron, re-solder the wires to the circuit board.
Kyle Kramer
crwdns2935283:001/16/19crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G6, Crawford Winter 2019 crwdns2935289:0Eastern Washington University, Team S1-G6, Crawford Winter 2019crwdne2935289:0
EWU-CRAWFORD-W19S1G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 230
