Motorola MBP667CONNECT Circuit Board Replacement
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
  2. Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
  3. Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
  4. Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola MBP667CONNECT Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
Jordan Webb
crwdns2935283:001/16/19crwdne2935283:0
112 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G6, Crawford Winter 2019 crwdns2935289:0Eastern Washington University, Team S1-G6, Crawford Winter 2019crwdne2935289:0
EWU-CRAWFORD-W19S1G6
crwdns2942667:0crwdne2942667:0 509
