In case of depleting battery life and battery damage, this guide is for consumers who need to replace the battery of their Motorola MBP667CONNECT baby monitor.
The battery casing is on the back of the monitor housing.
Notice the little crevice at the bottom of the baby monitor. This is how the lid is removed. Simply put pressure with your finger to the crevice and lift.
Remove the battery casing lid from the back of the monitor housing.
There is a plastic part connecting the wires of the battery to the device.
Disconnect the battery wiring from the monitor battery connection.
Remove and discard the old battery and replace it with a new battery.
just bought the battery linked and it has a slightly different, incompatible fitting. If i find one that works I’ll post…
