Motorola Krzr K1m LCD Replacement
  1. Motorola Krzr K1m LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Krzr K1m LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $3.99
    • Begin by removing the trim piece from around the front face plate.
    • Be very careful when dealing with the trim. It is very delicate, so be cautious when approching this next part.
    • Using your fingers or The Spudger get underneath the trim. Start by applying enough force to pry the trim off.
    • Be patient when trying to pry off the trim. The tape attaching the trim to the phone is very strong. Just be persistent and patient and it will eventually give.
    • Remove the trim piece.
  2. Motorola Krzr K1m LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Krzr K1m LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
  3. Motorola Krzr K1m LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Krzr K1m LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $3.99
    • Gently use The Spudger towards the edge of the phone and lift the face plate off.
    • The touch-sensitive keys and chip board/LCD screen (which is green) may remain attached to the face plate because of the glue.
    • Gently hold the green logic board down as you lift the face plate apart from it.
    • Remove the face plate.
  4. Motorola Krzr K1m LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Krzr K1m LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Krzr K1m LCD Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to.
    • Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone.
    • Replace with new green logic board/LCD screen.
    • To reassemble the phone, follow of the steps in reverse order.
Jennifer Hudiono
crwdns2935283:001/13/10crwdne2935283:0
42 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-1, Forte Winter 2010 crwdns2935289:0Cal Poly, Team 11-1, Forte Winter 2010crwdne2935289:0
CPSU-FORTE-W10S11G1
crwdns2942667:0crwdne2942667:0 6,621
