Motorola G30 screen replacement
  1. Motorola G30 screen replacement, Remove SIM card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card tray with a pin or a small pointy object
  2. Motorola G30 screen replacement, Unclip the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the plastic back cover using any tool you like (mediators, sprudgers, Jimmy...)
    • Be careful not to lift the cover too far from the phone, it has to be lifted cautiously because a cable is attached to it
  3. Motorola G30 screen replacement, Unscrew the optical cover part: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Unscrew the optical cover part: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slighly move the back cover in order to unscrew the plastic piece behind it
    • Remove the 9 small Philips-head screws inside
    • You will also have to remove small black adhesive pieces to be able to remove the part completely
  4. Motorola G30 screen replacement, Free the back panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the black plastic cover piece is removed, unplug the cable holding the back panel
    • Once this flex cable unplugged, lift the back panel completely
  5. Motorola G30 screen replacement, Unplug battery and screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug both battery and display connectors
    • Battery on the right
    • Display in the middle
    • You can use the opening tool as lever.
  6. Motorola G30 screen replacement, Unglue the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Very carefully unglue the battery
    • Adhesive is quite strong here, and the battery is not very rigid, so this is a complicated operation. It would be dangerous to head the battery cell, be patient and careful.
  7. Motorola G30 screen replacement, Disconnect the bottom PCB: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the cover at the bottom of the phone
    • 7 small Philips head screws to remove
    • A little black adhesive to peel off around the edges
    • Unplug the connector
  8. Motorola G30 screen replacement, Unglue display cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the display flex cable from the back of the chassis
  9. Motorola G30 screen replacement, Remove the screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola G30 screen replacement, Remove the screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola G30 screen replacement, Remove the screen: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Steps 9 and 10 are only useful if you order the display without its frame. Move on to step 11 if you intend to order the display with its frame
    • Heat up to help unglue the screen
    • Battery has to be removed first, heating batteries is dangerous
    • Unglue the display from the chassis
    • I could not properly unglue with a cutter blade on the side. My technique is simpler and more brutal: I pushed the display away from the connector hole, with a rigid tool.
  10. Motorola G30 screen replacement, Clean up the frame: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the glass shards still glued around the frame
    • Put some gloves on, because glass shards are dangerous!
  11. Motorola G30 screen replacement, Optional: test phone: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Optional: test phone: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replug the battery pack
    • Test the battery voltage on the test point to the left of the connector (the ground is everywhere on the metal chassis): it must be between 3.6 and 4.2 V
    • You can also test the motherboard with a Linux-based computer
    • Unglue the screen-USB-motherboard flex cable from your broken screen, and replug the bottom USB board with the top motherboard
    • Turn on phone with Power On + Up buttons
    • Plug it to the computer with an USB-C cable
    • Type "lsusb" in a shell
    • If you can read something like "22b8:XXXX Motorola PCS moto g(30)", congratulations: your motherboard still lives
  12. Motorola G30 screen replacement, Order replacement screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Order replacement screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once your phone has been successfully torn down and tested, it is time to order the replacement screen
    • The part will cost you around 15-20€. You can find it here for instance
    • Two choices: ordering the display pre-assembled on a new frame, or ordering it without
    • I recommend pre-assembled display, it will be more sturdy and less subject to breaking
    • While waiting for your order, don’t forget to store your parts and small screw properly
  13. Motorola G30 screen replacement, Screen with frame: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you ordered the display pre-assembled on a frame, you will have to move all the components from the old chassis to the new one
  14. Motorola G30 screen replacement, Move the buttons: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola G30 screen replacement, Move the buttons: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola G30 screen replacement, Move the buttons: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will find the small button panel on the chassis side, unglue it carefully
    • Start by ungluing the black tape covering it
    • Unplug the button connector from the main PCB
    • Unglue the button flex board carefully
    • Glue it on the new chassis
  15. Motorola G30 screen replacement, Unscrew PCB from frame: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Unscrew PCB from frame: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew both PCB
    • The top one is held by 2 screws
    • The bottom one is help by one screw
  16. Motorola G30 screen replacement, Move top items: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola G30 screen replacement, Move top items: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola G30 screen replacement, Move top items: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the top PCB out of the chassis
    • Under it, there is a small undefined module, and an opaque sticker
    • Get the module out of its casing
    • Unglue the sticker under it
    • Replace both module and sticker on the other side
  17. Motorola G30 screen replacement, Unglue the haptic module: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Unglue the haptic module: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom PCB
    • The haptic module is under it, unglue it carefully
    • Start by the connector side
    • Once the connector side is lifted, it is easier to get to the rest of the module and unglue it
  18. Motorola G30 screen replacement, Salvage the stickers or replace them: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Try to salvage the stickers and glue them back to the new frame
    • You can also use new stickers
    • The pink sticker is a very thin thermal pad, you can replace it by thermal paste
    • The orange sticker is a tape copper foil
    • I don’t know how to replace the metallic grey thing, it is probably use for a better RF shielding
  19. Motorola G30 screen replacement, Insert the top PCB: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Insert the top PCB: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the top PCB into the new frame
    • Don’t forget to move the button PCB small connector out of the way, it could get stuck under the board
  20. Motorola G30 screen replacement, Plug the elements back: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug the elements back
    • Top and bottom screen module connectors
    • Right-side antenna cable
    • Small button PCB connector
    • Screw the boards back in place
  21. Motorola G30 screen replacement, Rescrew covers: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola G30 screen replacement, Rescrew covers: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replug the back cover connector
    • A step you don’t see on the pictures because I forgot
    • Rescrew the two PCB covers
  22. Motorola G30 screen replacement, Clip the cover back into place: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clip the cover back in place
    • Insert the SIM card holder
Unfortunately, my phone is bricked, so I could never turn it on and test the new screen. I hope you will get more luck than me!
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Eve Redero
crwdns2935283:002/28/22crwdne2935283:0
2,945 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 2,432
