Motorola Entice w766 Motherboard Replacement
  1. Motorola Entice w766 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the tab off the back of the device.
  2. Motorola Entice w766 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tab located at the top of the battery to release the battery.
  3. Motorola Entice w766 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Entice w766 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Entice w766 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The six screws need to be taken out with any conventional screw driver tool.
    • You will have to unscrew the six 5.31 mm Star Head #5 screws with the appropriate six star bit.
    • There should be six screws removed from the casing after completion.
  4. Motorola Entice w766 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Entice w766 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Entice w766 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First you will need to locate the lip on the left side of the device.
    • Next you will insert the black spudger firmly into side opening to loosen the casing.
    • Using the blue pry tool gently remove the black and silver casing.
    • The motherboard should then be exposed after removal.
  5. Motorola Entice w766 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Entice w766 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Entice w766 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the flex cable with a pair of tweezers.
    • Be gentle with the flex cable as not to break the connecting wire.
    • Now use a spudger or pry tool to place firmly under the motherboard.
    • After creating clearance with the spudging device grab and remove the motherboard with a clamping tool or hand.
    • Look at the motherboard for scorches or loose pieces which could indicate damage.
    • Refer to the troubleshooting page for further advice to replace the motherboard.
Aalan Miranda
crwdns2935283:009/29/16crwdne2935283:0
210 crwdns2915208:0crwdne2915208:0
IUPUI-Harley-F16S2G4 crwdns2935289:0IUPUI-Harley-F16S2G4crwdne2935289:0
Community
crwdns2942667:0crwdne2942667:0 354
