Use this guide to replace the midframe on your Motorola Defy.
Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
Use a plastic opening tool to pry the battery out of the phone.
Unscrew the two silver screws located at the top of the back of the phone.
Use a plastic opening tool to gently pry the midframe from the rest of the phone.
