Motorola California Mobile Phone Keypad Guard Replacement
  1. Motorola California Mobile Phone Keypad Guard Replacement, Keypad Guard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Keypad Guard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Keypad Guard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide off the antenna guard.
    • Locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the old key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Keypad Guard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the circular extensions protruding from the top of your new key guard.
    • Push inwards on the small tabs on the side of the protrusions until they are no longer sticking out.
    • Note: This may require a strong push.
  5. Motorola California Mobile Phone Keypad Guard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the back case down on a table in front of you with the bottom of the phone close to you.
    • Put the key guard's tabs into the corresponding tabs on the bottom of the rear casing.
    • While the key guard's tabs are in the rear casing, put the rear casing's tabs into the bottom of the front casing.
  6. Motorola California Mobile Phone Keypad Guard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To join the 3 pieces together, push the front and rear casing together so that the clips on the front casing lock into the holes on the rear casing.
    • Slide the antenna guard on.
  7. Motorola California Mobile Phone Keypad Guard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the holes that connect the keypad guard to the rear casing.
    • Find a thin and sturdy screwdriver.
    • Use the screwdriver to push the rods away from each other until they click into a locked position.
    • Note: During usage, the key guard will not snap into place if it has not been locked into position.
Andrew Caddell
crwdns2935283:004/19/12crwdne2935283:0
10 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-46, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 9-46, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S9G46
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 3,511
