Motorola C290 Speaker Replacement
  1. Motorola C290 Speaker Replacement, Outside Case removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Speaker Replacement, Outside Case removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Speaker Replacement, Outside Case removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Speaker Replacement, Removing the front casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Speaker Replacement, Removing the front casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Speaker Replacement, Disconnect the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Speaker Replacement, Disconnect the motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Speaker Replacement, Removing the motherboard/screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Speaker Replacement, Removing the motherboard/screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Speaker Replacement, Removing the motherboard/screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
  5. Motorola C290 Speaker Replacement, Speaker Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Speaker Replacement, Speaker Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Speaker Replacement, Speaker Removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert spudger underneath the speaker.
    • Gently break the sticky seal between the phone case and speaker.
    • Lift the speaker off the phone case.
    • Note: It will be necessary to destroy the seal to remove the speaker.
Philip Ybarra
crwdns2935283:004/15/10crwdne2935283:0
27 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-28, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 24-28, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S24G28
crwdns2942667:0crwdne2942667:0 1,272
