Motorola C290 Logic Board Replacement
    1. Motorola C290 Logic Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Logic Board Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Position Motorola C290 so that the back of the phone is facing up.
      • Apply pressure to the back cover while simultaneously sliding it downwards.
      • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
    2. Motorola C290 Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Logic Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place your finger in the notch at the top of the battery.
      • Gently lift and pull out battery.
    1. Motorola C290 Logic Board Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Logic Board Replacement, Antenna: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Logic Board Replacement, Antenna: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew antenna head from top of phone by twisting counterclockwise.
      • Pull the antenna out through the top hole and set aside.
    2. Motorola C290 Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Logic Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
    1. Motorola C290 Logic Board Replacement, Logic Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Logic Board Replacement, Logic Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Logic Board Replacement, Logic Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
      • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
      • Note: This will reveal a screw. Five screws should now be visible.
      • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
    2. Motorola C290 Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Logic Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool in the groove at the top of the phone.
      • Rotate the tool to create an opening between the logic board cover and case.
    3. Motorola C290 Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Logic Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
      • Remove logic board cover and set aside.
    4. Motorola C290 Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Spudger to detach the screen wire from the logic board.
    5. Motorola C290 Logic Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Logic Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Logic Board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the Spudger into the slot on the top of the logic board.
      • Gently pry to loosen the top of the logic board.
      • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
      • Grab the top of the logic board and pull at an angle to remove.
Paul
crwdns2935283:004/15/10crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-28, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 24-28, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S24G28
crwdns2942667:0crwdne2942667:0 1,886
