Motorola C290 Keypad Replacement
crwdns2869540:0crwdne2869540:0: 1.7K
3
18
79
1,675
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
This repair guide describes how to replace the number keypad of the Motorola C290.
    1. Motorola C290 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Position Motorola C290 so that the back of the phone is facing up.
      • Apply pressure to the back cover while simultaneously sliding it downwards.
      • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
    2. Motorola C290 Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Keypad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place your finger in the notch at the top of the battery.
      • Gently lift and pull out battery.
    1. Motorola C290 Keypad Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Keypad Replacement, Antenna: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Keypad Replacement, Antenna: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew antenna head from top of phone by twisting counterclockwise.
      • Pull the antenna out through the top hole and set aside.
    2. Motorola C290 Keypad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Keypad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
    1. Motorola C290 Keypad Replacement, Logic Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Keypad Replacement, Logic Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Keypad Replacement, Logic Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
      • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
      • Note: This will reveal a screw. Five screws should now be visible.
      • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
    2. Motorola C290 Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Keypad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool in the groove at the top of the phone.
      • Rotate the tool to create an opening between the logic board cover and case.
    3. Motorola C290 Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola C290 Keypad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
      • Remove logic board cover and set aside.
    4. Motorola C290 Keypad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Spudger to detach the screen wire from the logic board.
    5. Motorola C290 Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola C290 Keypad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola C290 Keypad Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the Spudger into the slot on the top of the logic board.
      • Gently pry to loosen the top of the logic board.
      • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
      • Grab the top of the logic board and pull at an angle to remove.
    1. Motorola C290 Keypad Replacement, Keypad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your fingers to pull out the keypad.
      • Note: The keys and rubber backing are one piece.
Angelo Ballungay
crwdns2935283:004/15/10crwdne2935283:0
79 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-28, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 24-28, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S24G28
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 79
crwdns2959996:0crwdne2959996:0 1,675
