Turn the phone so its back is facing you.
Press the release button on the back cover, while simultaneously pulling the cover down.
Remove the back cover.
Pinch the sides of the bottom of the battery and pull upward.
Press and slide the SIM card down.
Remove the SIM card.
Orient the phone so its back is facing you.
Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Lodge a spudger in between the front panel and the main frame of the phone.
Using a good amount of torque, pry the front panel from the phone.
