Motorola Atrix 4G Bottom Speaker Replacement
  1. Motorola Atrix 4G Bottom Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the back cover off the back of the phone.
  2. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $3.99
    • Insert a spudger into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Bottom Speaker Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Atrix 4G Bottom Speaker Replacement, Antenna: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Use gentle force while unscrewing to avoid stripping the screws.
  4. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Tool
    $1.99
  5. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Gently lift the tabs located at the top of the phone using an opening tool.
    • Gently lift the tab located at the bottom of the phone with the same tool.
    • Use an opening tool, not your fingers, because the plastic tabs are easily broken.
  6. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Insert an opening tool between the front and back of the case.
    • Slide the tool down the side of the phone.
    • Repeat the same process for the other side.
    • There should be a noticeable gap between the front and back cases. If not, repeat this step.
  7. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the back case off the phone.
    • Do not completely separate the back case from the phone. The antenna is connected to both cases.
  8. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the antenna and lift straight up from the motherboard.
    • Lift straight upwards, not at an angle, to avoid damaging the socket underneath.
  9. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ease the antenna from out of its guide along the side of the phone
    • Remove the back case and the antenna from the phone.
    • The antenna is soldered to the back case. When reassembling, do not pull it with too much force.
  10. Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $3.99
    • Insert a spudger between the black plastic and the motherboard.
    • Lift upwards with the spudger to dislodge the board.
    • The motherboard should lift up easily. If the white rubber piece shifts, move it back to its original place.
  11. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Disconnect the press connectors using a spudger.
    • If you are unfamiliar with using connectors, consult this guide.
  12. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Lift the white latch on the ZIF connector using a spudger.
    • Gently pull the black ribbon down and away from the latch.
  13. Motorola Atrix 4G Bottom Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
  14. Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker can be found on the bottom of the inside of the back case and is held in by glue.
    • Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
Jake
crwdns2935283:004/19/12crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-42, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 9-42, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S9G42
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 3,638
