Replacing the battery of a Motorola V750 Adventure is an easy process. With a simple snap of the cover, removal of the battery, and addition of a new one, the battery can be replaced in seconds.
Turn phone so the back panel is facing up. Then locate the latch at the top of the back panel (above the Verizon logo).
With a fingernail, push down on the latch and remove the back cover.
Turn the phone over so that the battery text is facing right side up. With a spudger, lift from the bottom of the battery until it disconnects.
With a new battery, put into the battery slot top end first, then push down with your finger to secure the battery.
To reassemble your device, follow the previous instructions in the reverse order.
