Moto E5 Plus Screen Only Replacement
  1. Moto E5 Plus Screen Only Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back and frame of this phone is made of plastic. Be careful when heating the phone.
    • Apply heat, then use a suction cup to lift the back enough to fit an opening pick underneath.
    • Proceed to separate the adhesive around the edges of the phone, reapplying heat as needed.
  2. Moto E5 Plus Screen Only Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Halberd Spudger
    $2.99
    • The back of the phone is still attached via the fingerprint sensor's ribbon cable.
    • Gently pull the back of the phone towards the charging port to reveal the shielding plate.
    • Remove the screws and the metal plate.
    • Disconnect the fingerprint sensor cable using a Halberd spudger or opening pick and remove the back of the phone.
  3. Moto E5 Plus Screen Only Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moto E5 Plus Screen Only Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 15 #00 Philips screws.
    • Insert the pointed end of a spudger underneath the plastic midframe on either side of the battery and pry upwards to disengage the clips.
    • Remove the midframe.
  4. Moto E5 Plus Screen Only Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery.
    • Remove the battery. The battery has adhesive on each side.
    • Use small amounts of isopropyl alcohol to soften the adhesive if you are having difficulty removing the battery.
  5. Moto E5 Plus Screen Only Replacement, Screen Only: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening pick or spudger to disconnect the display ribbon cable.
    • Gently peel the display ribbon cable away from the phone frame as shown. It will remain attached to the display assembly.
  6. Moto E5 Plus Screen Only Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently heat the top of the phone to soften the adhesive. Use a suction cup to lift the display and insert opening picks.
    • Starting from the top, separate the display from the frame.
    • The display cable is attached to the bottom half the display.
    • There is a thin flexible plastic frame between the main phone frame and the glass. Check if the replacement part has this frame included.
    • For reassembly, B7000 adhesive is recommended over TESA adhesive tape due to the tight tolerances .
To reassemble your device, follow these instructions in reverse order. B7000 adhesive is highly recommended to attach the replacement screen to the frame.
crwdns2935229:016crwdne2935229:0
Patrick
crwdns2935283:005/14/14crwdne2935283:0
6,767 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2942667:0crwdne2942667:0 11,353
