Motion Computing LE1600 Speaker Modules Replacement
    1. Motion Computing LE1600 Speaker Modules Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the device so the screen is facing down.
    2. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the battery lock switch next to the power slider to the unlocked position.
    3. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
      • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
    1. Motion Computing LE1600 Speaker Modules Replacement, Bluetooth Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew hard drive panel using a Phillips head #1 screwdriver.
      • (Our device was not given to us with a hard drive or a hard drive panel)
    2. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull clear plastic tab to detach hard drive from tablet.
    3. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
    4. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the brown tabs to disconnect the white ribbon cable on the other side.
    5. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Caution: do not pull on the wires, instead pull from the plastic connectors.
      • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
    6. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
    7. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger, press in the five tabs on the side where the battery was.
      • This should separate the two halves of the device. Carefully set the side with the display off to the side.
    8. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the Bluetooth board.
      • Disconnect the ribbon cable by pulling on the plastic connector.
    9. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the 4mm screw holding the board onto the tablet.
      • Lift the board out of the tablet and carefully set it aside.
    1. Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
    2. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
    3. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
    4. Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motion Computing LE1600 Speaker Modules Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unstick the white masking tape and the black electrical tape holding the black and red wire down.
      • Pull out the wire and speaker.
David Troy
crwdns2935283:004/04/12crwdne2935283:0
44 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-14, Forte Spring 2012 crwdns2935289:0Cal Poly, Team 15-14, Forte Spring 2012crwdne2935289:0
CPSU-FORTE-S12S15G14
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 1,639
