Turn off the computer.
Take the slide unlocked into position, remove the battery.
Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
Now lift the cover carefully.
Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
Use a Phillips # 1 screwdriver to screw that holds the CD / DVD drive in place.
Pull the CD / DVD drive carefully out
Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
Insert a standard screwdriver into the slot in the cover above the keyboard.
Lift the cover with the usual care.
Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
Turn the keyboard towards the screen.
Carefully remove the connection cable in the direction of the plug axis.
Disconnect plug A.
Disconnect plug B.
Using the Phillips # 1 screwdriver, remove the 16 screws that secure the cover.
Using a Phillips #1 screwdriver, remove all 16 screws that secure the entire cover.
Using a Phillips #1 screwdriver, remove the other screw located on the back.
Remove the connector for the touchpad.
To remove the keyboard frame, start with the upper part on the right. (Visual access to the clips through the opening of the CD/DVD drive) by inserting a small normal screwdriver or better a small guitar pick
Then continue with the lower part.
Proceed with the removal of the keyboard bezel in the clockwise direction.
Remove the keyboard frame and the motherboard appears.
Unplug the main connector.
Unplug the small connector in the middle.
Turn the computer over and unplug the connector near the processor (CPU).
Remove the other connector that is immediately to the right of it.
Using a Philips #1 screwdriver, remove the 2 mounting screws of the Wi-Fi chipset.
Unplug the plug that is positioned in the back
Disconnect the small connector that is right next to the first connector.
With a Philips #1 screwdriver, remove the screws outlined in red.
Using a Philips #1 screwdriver, remove the 10 mounting screws from the motherboard.
Disconnect the small connector that is located in the front.
With a Philips #1 screwdriver, remove the 2 screws that are crosswise and marked with blue circles.
Take out the motherboard.
For reassembly, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
