The hull seen from the front.
The case seen from the back, with the jacks where to connect your handsets
Enough to redo a shell in case of problems, but without the feet.
The T14 snake-eyes tip to disassemble the facade.
Collars to block the jacks of your handsets under the shell.
Replacement snake eyes M6 screws, M6 inserts to remake a shell
Use the tip to disassemble the screws.
DO IT MANUALLY!!!
Not to the screwdriver, because it will rip. And the tip will damage the facade.
To block the jacks of the handsets: make a knot on the collar.
Thus, users will not be able to disconnect the handsets
If you want to redo a shell:
You have to cut the inserts, and pierce the bottom to pass the usb plug and the jack that connects to the tablet.
Take the model delivered as an example
To change the content of the micro SD card:
You must disassemble the facade, remove the tablet from the shell and open the "SD card" hatch
Create a file named: sexbreizh.avi
AVI container, mp3 audio codec, xvid video codec
Audio bitrate: 44100
Video rate: 8000
Om het apparaat weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
