Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
Remove the black putty from the speaker wires at both ends of the speaker board.
Solder the black plastic encasing the red and black wires.
Remove both the black and red wires with pliers
Tuck wires through the hole where the speaker is located, then gently push the speaker out.
