The heating element and temperature sensor are very important in a 3D printer. The former helps to melt the printing material to allow construction, and the latter monitors the temperature of the hot end. When both are faulty, the printer will begin to fail and require replacement.
That is the purpose of this guide: to help to replace both the heating element and the temperature sensor. Additionally, if only one of the two components need replacement, the parts of each step involving the other element can be ignored.
Use needle nose pliers to remove the two spring clips on either side of the shroud covering the hotend.
Remove the fan with your hand.
Remove the two 18 mm Phillips head screws that secure the shroud.
Remove the hot end from the shroud.
Use a small utility knife to cut the insulation covering the heater block.
Pull back the insulation until you have access to the grub screw at the bottom of the heater block.
Use the hex driver to loosen the grub screw.
Remove the heating element from the heater block.
Use the dull side of a utility blade to scrape away excess thermal compound holding the temperature sensor in place.
Remove the temperature sensor.
Unwind the spiral wrap from the wires leading from the hotend to the printer body.
Lay the printer in its back to access the bottom panel.
Remove the six 8 mm Phillips head screws, and carefully remove the bottom panel.
Clip the zip ties holding the wire bundle together.
Locate the pair of thick red wires for the heating element and the pair of thin white wires for the temperature sensor.
Find where each pair of wires connects to the main board and disconnect them with a pair of needle nose pliers.
Remove the four Phillips head screws holding the vertical section of the printer to the base.
Remove the vertical portion of the printer from the base.
Feed the wires for the heating element and the temperature sensor through the hole in the base.
Remove the three Phillips head screws from the bottom of the vertical assembly that hold the front panel in place.
Remove the three Phillips head screws from the top of the vertical assembly that hold the front panel.
Remove the front panel from the vertical assembly.
Push the wires for the heating element and the temperature sensor through the hole in the top of the vertical assembly.
Cut the remaining zip ties holding the wires together.
Unwind the remaining wire wrap from the bundle of wires.
Remove the old heating element and temperature sensor.
Insert the new heating element into the heater block.
Tighten the grub screw to secure the heating element.
Insert the new temperature sensor into the heater block.
Use kapton tape to secure the insulation around the heater block.
Feed the wires from the new components through the hole at the top of the vertical assembly.
From this point, use steps 15-1 as a guide to reassemble the device, ignoring steps 4 and 5.
Very good. It would be simpler, for those who can contemplate it, to just cut the wires to the heating element and thermistor a couple of inches away from them. and splice the new ones in, paying attention to heat-shrinking the joints. Then you don't have to rewire all the way back to the PCB. You need soldering and heatshrinking facilities for this procedure.
The 'you need' list should also include zip ties.
Where did you get the new heating element? Would this fix the issue of the printer not printing anything, even after preheating it? That's why mine has been collecting dust for years.
