Moen Single Handle Faucet Cartridge (Model: 1225) Replacement
  1. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees counterclockwise to the closed position.
    • If you have a gate valve, rotate the valve counterclockwise to the closed position.
  2. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the faucet handle to relieve water pressure until there is no water flow.
  3. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the handle cap.
  4. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to unscrew the connecting handle screw (10-24 x 1-1/8" Button Head Phillips screw).
    • Remove the handle.
  5. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the stop tube.
  6. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the washer from the brass stem.
  7. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using needle-nose pliers, clamp the tip of the notch of the cartridge retaining clip and pull it upwards to remove.
  8. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of vise grips, clamp firmly onto the brass stem and pull out the old 1225 cartridge.
  9. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the new 1225 cartridge, orient the volume control holes parallel to the floor.
    • Insert the new 1225 cartridge into the valve.
  10. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the white twisting cap into the grooves of the new cartridge and push the cartridge into the valve.
    • Remove the white twisting cap.
  11. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinstall the cartridge retainer clip by sliding the clip into the valve.
  12. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn on the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees clockwise to the open position.
    • If you have a gate valve, rotate the valve clockwise to the open position.
  13. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clamp the brass stem with vice grips and rotate it 90 degrees to the left, checking the water temperature for hot water.
    • From this position, rotate the brass stem 180 degrees to the right, checking the water temperature for cold water.
    • If the hot and cold operations are reversed, use vice grips to clamp onto the brass stem and rotate it 180 degrees from the original position.
  14. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the washer onto the brass stem.
  15. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the stop tube by pushing it onto the valve.
  16. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the handle onto the stop tube.
    • Use a Phillips screwdriver to screw in the connecting handle screw (10-24 x 1-1/8" Button Head Phillips screw).
  17. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the handle cap.
If your faucet continues to leak after replacing the cartridge, there may be another underlying issue causing the problem with your plumbing. Inspect the O-rings, seals, and other components of the faucet for any damage and consult professional assistance to resolve the issue.
Faith Larimore
crwdns2935283:007/05/23crwdne2935283:0
325 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 1-4, Meigs Summer 2023 crwdns2935289:0Austin Community College, Team 1-4, Meigs Summer 2023crwdne2935289:0
AUSTINCC-MEIGS-SU23S1G4
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 202
crwdns2942667:0crwdne2942667:0 3,615
