Model O- Mouse Cable Replacement
  1. Model O- Mouse Cable Replacement, Mouse Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Model O- Mouse Cable Replacement, Mouse Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Model O- Mouse Cable Replacement, Mouse Cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
  2. Model O- Mouse Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
  3. Model O- Mouse Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
  4. Model O- Mouse Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
  5. Model O- Mouse Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
  6. Model O- Mouse Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
  7. Model O- Mouse Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
  8. Model O- Mouse Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
  9. Model O- Mouse Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Model O- Mouse Cable Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
Theo SW
crwdns2935283:001/22/21crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
York University, Team S2-G24, O'Regan Winter 2021 crwdns2935289:0York University, Team S2-G24, O'Regan Winter 2021crwdne2935289:0
YORK-O'REGAN-W21S2G24
Where can I get the replacement cable for it?
Ekke Sten - crwdns2934203:0crwdne2934203:0
does glorius them selfs sell replacment parts ?
aniss-97 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 13,115
