In this guide we will be showing one how to replace the forward and backwards buttons to a Modal Rechargeable Wine Opener in 5 quick and easy steps.
Carefully place the spudger under the black cylindrical ring and pry it off the top.
Remove the spring
Remove the spring guide as well to obtain clear access to the screws
Remove all four 4mm screws with a J1 Screwdriver
Remove the clear cylindrical cap
Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
Remove the malfunctioning buttons from the plastic frame.
where do you by the replacement switch?
are there any posts for fixing the usb charging port?
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
Could be also the battery. I will try to change the battery.
