Modal MD-WORCSS6 Motor Replacement
  1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
  2. Modal MD-WORCSS6 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
  3. Modal MD-WORCSS6 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
  4. Modal MD-WORCSS6 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
  5. Modal MD-WORCSS6 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel the tape off far enough to remove the 3 batteries.
  6. Modal MD-WORCSS6 Motor Replacement, Motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement, Motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Modal MD-WORCSS6 Motor Replacement, Motor: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the circuit board out of its slot.
    • Pull the white plastic neck down and out of the slot. Remove the neck and body spring.
  7. Modal MD-WORCSS6 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use wire cutters to cut the wires connected to the bottom of the motor.
    • Remove the motor from the plastic body.
  8. Modal MD-WORCSS6 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip the insulation from the wire up to about half an inch from the end of the exposed wire.
    • Attach a new motor to the device by re-soldering the connections that were cut earlier.
    • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
Michael Richard Cassell
crwdns2935283:010/02/19crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G13, Eggleston Fall 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G13, Eggleston Fall 2019crwdne2935289:0
CMCSC-EGGLESTON-F19S3G13
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 142
